So, I do have a static IP assigned to me. So, wan is defined as such, with static ip, gateway, etc. per ISP requirement. Merlin 380.59.
When what I assume is the ISP down, the network map wan status screen shows no wan ip, no gateway, etc. I assume this is "normal" if the ISP is having trouble, even though static ip? Cpu #2 then goes to 100% usage.
Just want to understand if this is normal. Being super rural, I have a WISP and things just happen on them at times.
