D
Deleted member 27741
Guest
Hi all been a long time since I rapped at you.
Want to stream steam games via vpn? My N66U's PPTP works like a charm (windows rdp will block the console though so use another remote program to access the stream server if possible). If you must use windows rdp (I use it to start steam on my stream server) you can run the following AS ADMIN in a batch file to unblock the screen for streaming.
for /f "tokens=4 delims= " %%G in ('tasklist /FI "IMAGENAME eq tasklist.exe" /NH') do SET RDP_SESSION=%%G
echo %RDP_SESSION%
C:\Windows\System32\tscon.exe %RDP_SESSION% /dest:console
I cannot get openvpn working reliably for vpn steam streaming, probably not worth the effort when PPTP works so well and you don't really need fort knox encryption for gaming. I do hope that maybe John's newest version (with updated openvpn) will allow openvpn to be used, but getting it working would be more of an academic exercise, seeing as how PPTP is faster.
echo %RDP_SESSION%
