still having issues with openvpn client setup
Revelstone77
I'm using Merlin's 380.66_6 and want to route specific clients out over the tunnel and the rest over the Wan. In this scenario, do i have to essentially create an entry for every device on the network and specify Vpn or Wan? I have created entries for the devices i want to go out the tunnel and those work fine. The problem i have is other devices that i dont want to go out the tunnel end up going out the tunnel, as proven by their external addresses. I'm using exclusive DNS and strict policy rules. All other settings either came from the .ovpn file or are default.
thanks
thanks
By default, all traffic will go through the WAN, except what you define there as being routed through the VPN.
