Dismiss Notice
Welcome To SNBForums
Store https certificate in NVRAM
Discussion in 'Asuswrt-Merlin' started by adolchristin, Feb 28, 2013.
  1. adolchristin
    adolchristin New Around Here
    Feb 28, 2013
    8
    First of all I'm a recent convert to merlinwrt and I must say that I think it's fantastic.
    Is there a way to store the certificate for https in NVRAM so it's not regenerated at boot every time?
  2. sabot105mm
    sabot105mm Regular Contributor
    Feb 1, 2013
    52
  3. adolchristin
    Feb 28, 2013
    8
    I'm not quite sure I understand. So once I have this certificate stored in jffs how do I use it to override the https server certificate in merlin wrt?
  4. ingenium
    ingenium Occasional Visitor
    Jan 22, 2013
    10
    Yeah, how would I set httpd to use this certificate instead of the auto-generated, self-signed one? I want to replace it with one that's trusted on my computers. I don't think it's in the NVRAM anywhere. "nvram show|grep CERTIFICATE" only brought up my VPN certificates. It doesn't look like the process has any more files open:
    admin@RT-AC66U:~# ls -l /proc/`ps | grep 'httpd -s' | awk '{print $1}' | head -1`/fd/*
    lr-x------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/0 -> /dev/null
    l-wx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/1 -> /dev/null
    lr-x------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/10 -> /tmp/Semaphore3
    l-wx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/11 -> /tmp/Semaphore3
    lrwx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/12 -> socket:[1641]
    lrwx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/13 -> socket:[1728]
    l-wx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/2 -> /dev/null
    lrwx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/3 -> /dev/nvram
    lr-x------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/4 -> /tmp/Semaphore0
    l-wx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/5 -> /tmp/Semaphore0
    lr-x------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/6 -> /tmp/Semaphore1
    l-wx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/7 -> /tmp/Semaphore1
    lr-x------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/8 -> /tmp/Semaphore2
    l-wx------    1 admin    root            64 Jun 18 02:27 /proc/557/fd/9 -> /tmp/Semaphore2
    I can't figure out what the Semaphore files are for... they all have a 0 byte size.
  5. ingenium
    Jan 22, 2013
    10
    I figured out the default locations for the certificate. It's the same as dd-wrt (I'm guessing the same http server is used).
    Put your certificate and key in /jffs/keys. Then add the following to /jffs/scripts/services-start
    mv /tmp/etc/key.pem /tmp/etc/key.pem.bak
    mv /tmp/etc/cert.pem /tmp/etc/cert.pem.bak
    cp /jffs/keys/key.pem /tmp/etc/key.pem
    cp /jffs/keys/cert.pem /tmp/etc/cert.pem
    service restart_httpd
Share This Page
