Struggling with remote access to router (settings)
superfly75
Hi there, I am struggling to configure my router in the Administration > System > Remote Access Config settings
I want to be able to :
1. Access from home
2. Access from WAN (Web only)
3. Whitelist 3 remote fixed IP address (4 if I include my own home fixed IP address)
All IP addresses involved here are fixed.
So I did the configuration as attached, however if I do this I am no longer to open the UI from home (local).
As anyone been able to make this work from both local (inside) and WAN (outside)?
Do I need to add my own IP address (home) in the whitelist? (I tried but did not work either)
Any help with this section would be greatly appreciated...
1. Access from home
if you enable Access Restrictions, then you'll also need to include the IP address of the local computer that you're using to access the UI from home. do not put your WAN IP in there.
You should be using an OpenVPN Server instance instead of what you need.
