speedlever
A couple of years ago I bought an Asus RT-N66U and promptly put the then current version of Merlin's software on it. I moved my old WRT54G to the other side of the house, ran a cat 5e cable to one of the LAN ports, turned off DHCP and let it extend my wireless coverage. I pretty much have left it all alone since then.
Now I'm getting the itch to replace the WRT54G with something dual band... and after reading the thread about using an AC router to boost N devices, I'm consider an inexpensive (<$100) AC router.
I considered buying another N66U but thought for the same money (~$100) I could get an AC router. I think I'll leave the current N66U as my main router and put the new one in place of the old WRT54G.
Both routers live in probably the absolute worst environment possible. The N66U lives behind my dual monitors in a corner office on the first floor and the WRT54G lives in the opposite side corner behind a 48" TV.
I named the SSIDs different so I can manually switch to the stronger signal when I'm in that part of the house. I don't want to pay for the tech that will keep me on the strongest signal!
What would you suggest to replace the WRT54G?
- DIR-850L
-EA-6900
- Archer C7-AC1750 (v2 is cheaper than C8 and seems to perform better)?
- AC-66U
- other option?
I thought I had saved notes about how I setup the WRT54G, but now can't find them. I thought I set the IP at 192.168.2.1 but can't seem to get on to check the settings.
That's the problem with figuring stuff out then not messing with it for a long time. I have to learn it all over again. Sigh. Where are those darn notes when you need them?
BTW, I have gigabit fiber ethernet and it routinely tests out around 900 Mbps down and 30 Mbps up. While I only have N devices in the house, many are dual band and with streaming becoming more and more popular, I'd like to up my capability.
I just wish I could get an affordable gigabit router with at least 6 gigabit ports.
- DIR-850L
-EA-6900
- AC-66U
- other option?
