I currently have the misfortune of living in close proximity to some anonymous person whose router announces a TW country code. Through a combination of unfortunate circumstances, this often has the effect of making my N66U's 5ghz network invisible to Macs, as the Airport network card (madly, inexplicably) determines its location from the first signal it detects and mine often hears the clarion call "TAIWAN!" over all the GBs and the X3 my router seems to announce, which means it adopts Taiwan's permitted frequencies and so stops listening on any of the bands my 5ghz network can use.
Here's what I'm seeing in terms of signals, channels, etc:
Some people have resorted to manually binary patching their Mac's network driver to fix this, which I don't want to risk. So for the time being, I've written an applescript package I can run that turns the airport card on and off until it detects a non-Taiwanese country code, but if anyone has any suggestions for what I can do to make my router's signal more likely to be picked up ahead of the Rogue network, it'd be much appreciated.
Rogue 2.4ghz Network
PHY Mode: 802.11n
Channel: 1
Country Code: TW
Signal / Noise: -79 dBm / -87 dBm
My 5ghz Network
PHY Mode: 802.11n
Channel: 48,-1
Country Code: X3 (though in Wireless Diagnostics, it shows up as EU)
Signal / Noise: -55 dBm / -87 dBm
Transmit Rate: 300
MCS Index: 15
My 2.4ghz Network
PHY Mode: 802.11n
Channel: 6
Country Code: -
Signal / Noise: -48 dBm / -87 dBm
PHY Mode: 802.11n
Channel: 1
Country Code: TW
My 5ghz Network
PHY Mode: 802.11n
Channel: 48,-1
Transmit Rate: 300
MCS Index: 15
My 2.4ghz Network
PHY Mode: 802.11n
Channel: 6
Country Code: -
