Support for ASUS RT-AC66U
randye007
Hi All,
  • RT-AC66U (hardware revision B1 is NOT supported)
How can I tell what hardware revision I have?
Thanks,
Randy
It is, still not officially, but flashing with RT-AC68U FW will work just fine.
Check the sticker on the router or router case/box.
Thanks hggomes!
I checked the sticker and have the following FCC ID: MSQ-RTAC66U. Does this somehow identify the hardware revision?
Thanks,
Randy
You are welcome, that means you have the first RT-AC66U model, the HW Ver is mention on the box.
Ah yes. I see from the box the HW rev is A1. So I can flash the RT-AC66U Merlin build. Perfect! Thanks again.
No problem. :)
