Synology DSM Android Access Issues
Shaun4BigBlocks
When I remote in to my Synology through one of my Linux, Windows, or Apple terminals all is good. When I try to use Firefox, Chrome, or Edge Beta on my Android devices I start running into problems.
I can log in with mobile mode, but then the screen is greyed out. I can also not pinch to zoom in mobile mode. I can force a desktop environment at which point everything on the surface works and looks fine. The issue is that I can not pinch to zoom. I would have to use like a micro stylus or something for selection- not going to happen. If I put the device in landscape orientation, I can now use my finger to select, but I can still not pinch to zoom and DSM does not offer a slider- so I can not browse down to see folders/files lower on my file tree.
I remember back in the day when you could just go into most bobile browser's setting and manually override website pinch to zoom settings. It has been a long while since I have had to do that, as pretty much everything I use on Android pinch to zoom pretty much just works as it should.
Granted I have not spent a lot of time on this, such as searching for an about:config option for example. I was kind of hoping someone has already had and resolved this issue, as my free time to screw with this is limited at the moment...
