I have been using AiMesh on over many AiMesh models for the past year and I would like to share some thoughts on AiMesh. Opinions are my own. Discussion welcomed.
Lack of proper roaming support
AiMesh does not support any of the 802.11 roaming standard. ASUS is relying on their roaming framework which in reality doesn't work well. It takes 500-1000ms to roam to an AiMesh node if you are lucky with some packet drop most of the time. This is certainly not seamless and definitely not able to keep a VOIP call connected. While roaming decision will depend on the client, the addition of 802.11 k/v/r support will make everything much better for supported devices.
Poor Cross Model Compatibility
While being cross model compatible is a huge AiMesh selling point, the compatibility is terrible when different models are involved. While staying with similar chipset vendor is fine (RT-AC68U & RT-AC86U). Mixing chipset will cause random glitches with no network or node not connected. (Blue Cave & RT-AC86U). This is even worst when you attempt to use an AX model with an AC model.
I found that the RT-AC86U + RT-AC86U combo will give the best performance and stability as it is always the first one to receive new firmware.
Too many parameters to control
While this is technically not ASUS fault. Optimally, ASUS should fix everything on a set of best known parameters when AiMesh is enabled rather than leaving it to the users to figure out manually. While power users will be fine, many casual users simply do not have the knowledge to perform this.
Firmware Issues
The way AiMesh is developed today is not really that user friendly. Updating firmware will sometime break AiMesh and users will need to perform a factory reset and start everything from scratch. At some point, people are going to get tired from having to deal with this constantly.
Comparing it to Google WiFi or Eero, although it doesn't offer a similar level of performance like a 4X4 AiMesh router, they are easier to manage and don't really requires the amount of time required to fine tune everything. It just work smoothly out of the box.
While I will give credit to ASUS for developing their own mesh protocol and backport it to their old models rather than relying on vendor's implementation such as Qualcomm SON. But, at this point it is still a mess and far from what the competitors can do (Eero, Google WiFi and etc)
Firmware Issues
