Hello!
Having just bought an N4800 I was very interested to see the performance graphs in your review. I bought the 4800 to replace an old, slow NAS and I wanted to store a lot of video and lossless audio so the files are large. I'd already bought and populated it before I found your review but you give it a good review so that's good, heh.
My 4800 now has 4 x 3TB Seagate ST3000DM001-9YN1 in unencrypted raid 5. They're on the compatibility list (minus the -9YN1 part) and are all listed as healthy. They all pass the short test and they list as SATA 3Gb/s even though I think they're actually 6 but I assume that's because the 4800 is only 3. On the whole I like the 4800 so far. Good interface, easy RAID/network setup, nice neat little quiet box even with 4 drives twirling merrily. Pretty much it all just worked straight away.
My post stems from the fact that you seem to get a much better transfer to and from the 4800 than I can get. I'm not a network storage whizz by any stretch so I'm not entirely sure what constitutes "good" performance. It's also equally possible I'm just misreading your charts!
I mentioned the unencrypted bit above as at first I thought that was my problem. When I initially created the array I stuck a memory stick in the front and encrypted the array, mostly because I could to be honest. I figured there'd be a performance hit but was curious how much it was. I performed a hugely unscientific test of copying a single large (19.1 GB) file onto it and it capped out about 25 MB/s. This is better than my old NAS by far (don't ask) so I wasn't displeased. I then deleted the array and recreated it as unencrypted for comparison. That capped about 35 MB/s. This is single file write from an Ubuntu 10.10 desktop over SMB, reading from flash. Copying multiple (semi-large 25-30 MB) files from flash onto it give the same figure. Reading back the same file from the NAS caps about 41 MB/s, writing to magnetic (my flash drive is full). Both (desktop and NAS) network adapters are listed as 1000 Mb/s.
I stuck a crossover cable in LAN2 direct to the desktop and got the same figures so it's probably not my cheap switch. I'd already had cable problems using a 5e that dropped the network to 100 so all the cables are cat 6.
As I said, I'm not displeased with the 4800 at all - it beats my old NAS into a cocked hat so it's all good. I'm just curious though why my figures are seemingly so far from your graphs. You have figures of 90 MB/s upwards yet I can't break 45!
Any fault finding or tuning tips gratefully accepted. I'm not a network engineer so I'm open to the fact that my methodology is rubbish and I've misread your graphs!
edit: Sorry, filesystem is EXT4.
