Krazy Wabbit
Hello
Have the Asus TM AC1900 from T-Mobile a few years back. I upgraded to Cox's Gigabit plan using their provided Arris TM3402A modem. Hooked everything up similar to the older modem. Fired up speedtest and was happy with the results.
Later in the day, everything stopped. Went through the usual resetting router/modem. Internet would come back and then stop at various times. Sometimes 5 min later sometimes 20 min, 60, it varied. I then removed the Asus from the equation. Ethernet from modem directly to a PC or PS4. No issues.
So, it appears it's the Asus router. I've read through the forums, searched google and you tube and looking for any suggestions that I might try setting wise on the Asus or do I just need to buy a new router.
Many thanks!
Many thanks!
