TOR Network : how to block ?
Ricou31
Hello,
Is it possible to block TOR network with my RT-AC68U router with Merlin's firmware of course ?
Do you know where i can find information ?
Regards
Asus RT-AC68U with Merlin's firmware 380.68_4
Thanks for this link.
So it seems difficult to block the TOR network.
Not a good news ...
This can be partially done with Skynet quite easily. After installation just import a reputable node iplist. It's been mentioned in the thread previously if you give it a search.
To my surprise, I managed to install skynet. I am not a specialist. Now, I need to import an IP address list to block as much as possible the TOR network.
so I have to find the right list ...
I found a list (https://www.dan.me.uk/torlist). I obviously managed to import it into skynet using the command 5 (import) and specify the URL of the list that I previously stored on my site. IPs have been well integrated :
"6370 IPs / 0 Ranges Banned. 0 New IPs / 0 New Ranges Banned. 0 Inbound / 0 Outbound Connections Blocked!"
It remains to be seen now if it works.
Thank you
