Hi Folks,
Have been using Merlin for sometime now.
And I have to say I love it.
Have a AC56U and on that have been using transmission.
Recently I have started seeing this error in the sys log.
Couldn't bind port 32767 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
The firewall start script is correct, I tried netstat to see if anything else is hogging teh port.
I tried changing it, (Was on the then default 51413 and only changed it after getting errors).
I even did a complete factory reset and re-installed and reconfigured everything to no avail.
Had read somewhere that Ubuntu torrents may cause a problem and I incidentally had a ubuntu and linux mint torrent in there, removed those from the /opt/etc/transmission-daemon/resume.
Well of these tries and still cant get transmission to work.
I know this is not Merlin specific, but want to put in here:
Thank you in Advance!
Details:
Apr 17 23:48:39 transmission-daemon: Starting transmission-daemon...
Apr 17 23:48:40 transmission-daemon[6330]: Transmission 2.82 (14160) started (session.c:738)
Apr 17 23:48:40 transmission-daemon[6330]: RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:828)
Apr 17 23:48:40 transmission-daemon[6330]: RPC Server Serving RPC and Web requests on port 127.0.0.1:1521/transmission/ (rpc-server.c:1035)
Apr 17 23:48:40 transmission-daemon[6330]: RPC Server Whitelist enabled (rpc-server.c:1039)
Apr 17 23:48:40 transmission-daemon[6330]: RPC Server Password required (rpc-server.c:1042)
Apr 17 23:48:40 transmission-daemon[6330]: Couldn't bind port 32767 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
Apr 17 23:48:40 transmission-daemon[6330]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:78)
Apr 17 23:48:40 transmission-daemon[6330]: UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
Apr 17 23:48:40 transmission-daemon[6330]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:89)
Apr 17 23:48:40 transmission-daemon[6330]: UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
Apr 17 23:48:40 transmission-daemon[6330]: DHT Reusing old id (tr-dht.c:306)
Apr 17 23:48:40 transmission-daemon[6330]: DHT Bootstrapping from 44 IPv4 nodes (tr-dht.c:154)
Apr 17 23:48:40 transmission-daemon[6330]: Using settings from "/opt/etc/transmission-daemon" (daemon.c:526)
Apr 17 23:48:40 transmission-daemon[6330]: Saved "/tmp/mnt/sdb1/asusware.arm/etc/transmission-daemon/settings.json" (variant.c:1217)
Apr 17 23:48:40 transmission-daemon[6330]: Saved pidfile "/var/run/transmission-daemon.pid" (daemon.c:538)
Apr 17 23:48:40 transmission-daemon[6330]: transmission-daemon requiring authentication (daemon.c:546)
Apr 17 23:48:40 transmission-daemon[6330]: Watching "/mnt/YD128GBSSD/torrents/watchdir" for new .torrent files (daemon.c:564)
Apr 17 23:48:40 transmission-daemon[6330]: Using readdir to watch directory "/mnt/YD128GBSSD/torrents/watchdir" (watch.c:163)
Apr 17 23:48:40 transmission-daemon[6330]: Loaded 4 torrents (session.c:1994)
Apr 17 23:48:40 transmission-daemon[6330]: Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
Apr 17 23:48:40 transmission-daemon[6330]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
Apr 17 23:51:19 dnsmasq-dhcp[653]: DHCPREQUEST(br0) 192.168.1.235 18:97:ff:f0:32:20
Apr 17 23:51:19 dnsmasq-dhcp[653]: DHCPACK(br0) 192.168.1.235 18:97:ff:f0:32:20 android-6b9c7eb5d495fd29
admin@RT-AC56U-BFB0:/tmp/mnt/sdb1/asusware.arm/etc/init.d# netstat -a | grep 32767
admin@RT-AC56U-BFB0:/tmp/mnt/sdb1/asusware.arm/etc/init.d# iptables --list-rules | grep 32767
-A INPUT -p udp -m udp --dport 32767 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 32767 -j ACCEPT
admin@RT-AC56U-BFB0:/tmp/mnt/sdb1/asusware.arm/etc/init.d# cat /var/run/transmission-daemon.pid
6330admin@RT-AC56U-BFB0:/tmp/mnt/sdb1/asusware.arm/etc/init.d# ps | grep 6330
6564 admin 1376 S grep 6330
Details:
