Using RT-AC66R on 380.58.
Entware and Transmission are setup and running fine.
Only issue is that that Transmission web interface is not usable.
When I try to go to it, it loads the menu bars/buttons, but the torrents appear for a split second, then disappear...and these repeats endlessly.
This happens even when all torrents are stopped, so its not that the router is being overwhelmed with connections.
I use a chrome extension and android app to connect to Transmission(and these work fine), so its not a huge deal, but just wondering if anyone has a solution for this.
Any idea how to check if I have the latest version of Transmission, and if there's a way to easily update (without losing all my Transmission settings)?
Thanks very much.
Thanks very much.
