Unable to add OpenVPN Client
Ben Oosterom
Hi!
I've been trying to add OpenVPN clients to my RT AC68U router with Merlin 384.12. However, when I try to upload the .ovpn file, after 3/4 secondes the page refreshes, not even leaving me enough time to edit other properties. When I look up the log, it gives me this:
openvpn: Resetting client (unit 1) to default settings
I've already rebooted the router for it to format the jffs partition, but with no succes. What am I doing wrong?
Thanks in advance for the help!
Hi!
There is nothing wrong, this is exactly how it's meant to work. Default settings are first applied (to ensure only the changes from the ovpn files get applied), the content of the file tgen gets applied, then you get returned to the configured settings so you can make further changes.
Sent from my SM-T720 using Tapatalk
