unknown syslog copy
wheelq
I have noticed very high CPU spikes, so I did a little research.
As it turns out, every , the following command is being issued:
2984 admin     1420 D    cp /tmp/syslog.log /tmp/syslog.log-1 /jffs
I have checked the 1420 and it is:
 101 admin     1420 S    /bin/sh
Yes, I do lots of logging into the syslog. Here is my config launched after router reboot:
syslogd -m 0 -S -O /mnt/sda2/logs/new-syslog_0.1 -s 71200 -b 99 -l 7
Any idea what that is? I do not have any script in scripts folder containing the cp command mentioned above.
Thanks!
It’s a Merlin feature to backup syslog.log to jffs to persist through reboots.
I think that's standard Asus code, not specific to Merlin.
True enough. Let’s call it a firmware feature for purposes of his concern and not a rogue bit of malware. :p
AFAIK you can't because it's baked into the watchdog process.
I'd guess that because you've configured your router with such a large log file that there's not enough space in /jffs to write it. I'd also speculate that because the copy fails it is constantly repeating the process. I think the only practical solution would be to reduce the size of the log file.
Ok, any idea how to disable this?
Are you issuing a killall syslogd before staring your modified one? I'm not sure what would happen if you tried to start a second instance. Also you can disable copying the /tmp logfiles to /jffs by using:
rm /jffs/syslog.log && mkdir /jffs/syslog.log
rm /jffs/syslog.log-1 && mkdir /jffs/syslog.log-1
