Dismiss Notice
Welcome To SNBForums
Updated to Merlin build...is this correct?
Discussion in 'Asuswrt-Merlin' started by neil0311, Nov 27, 2012.
  1. neil0311
    neil0311 Regular Contributor
    Sep 29, 2012
    135
    Updated my RT-N66U from the stock Asus .220 build to Merlin build 3.0.0.4.246.20. Everything seems good, but noticed that not all of the 256MB of RAM is being reported.
    Is this correct or do I possibly have a hardware issue with bad RAM?
    Memory
    Total 234.25 MB
    Free 195.62 MB
    Buffers 5.22 MB
    Swap usage 0.00 / 0.00 MB
  2. Pierino
    Pierino Very Senior Member
    Jul 13, 2012
    533
    Ohio
    Yup, it's normal.
  3. DaveMishSr
    DaveMishSr Very Senior Member
    Jul 14, 2012
    539
    San Diego
    Here's what my RT-N66U running 246.20 reports:
    Memory
    Total 234.25 MB
    Free 65.07 MB
    Buffers 12.28 MB
    I have "enable DoS protection" enabled in the "administration/firewall" settings and I am assuming that is why my unit is using so much RAM.
  4. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    19,350
    Canada
    The Linux kernel needs to use some of that RAM for the OS.
    Dec 31 19:00:13 kernel: Memory: 238608k/131068k available (2520k kernel code, 22568k reserved, 512k data, 196k init, 131072k highmem
  5. RMerlin
    Apr 14, 2012
    19,350
    Canada
    DoS protection basically adds a few iptable rules that will throttle connections - it should have negligeable impact on RAM. Most likely your RAM usage is either DownloadMaster or AiCloud (one of the AiCloud services is a major memory guzzler if you leave it running for a few days).
  6. neil0311
    Sep 29, 2012
    135
    Thanks everyone. I assumed it was probably reserved to the OS or another function, but you know what they say about assuming. :)
  7. DaveMishSr
    Jul 14, 2012
    539
    San Diego
    I have both AiCloud and DownloadMaster running. Should I worry about that?
  8. RMerlin
    Apr 14, 2012
    19,350
    Canada
    Should be fine, except for AiCloud which I suspect might be increasing in memory usage over time. Keep an eye on your free memory. If it becomes a problem, you could configure a cron job to reboot your router automatically once a week in the middle of the night, or disable AiCloud if you don't use it.
Share This Page
