uPnP not working?
RdeN
I am using Transmission on my Macbook with Mountain Lion.
The port I have set to 51515, but it says port closed. Both on the router (RT-N66U) as on the modem uPnP is switched on.
It used to work when I had a different router in the past, so I don't think the uPnP on the modem is the problem.
I am using Merlin's build 3.0.0.4.266.23b.
Btw, I know I can have the router as BT client, but that is not what I am looking for. I am perfectly fine doing it via my Macbook.
Hi!
The same problems reported several times in russian thread.
Please, take a look how seeding is going. Looks like transmission got wrong report about closed port. If seeding goes well then port is real opened.
S RT-N66R stopped working, lights flashing ASUS N Routers & Adapters 2
