USB Modem connection with RT-AC3100 (Galaxy Note8)
rkinnc75
I'm trying to setup my Samsung Galaxy Note8 using the USB modem connection. When I connect the phone and set it to USB tethering it will recognize the device is connected, but it will never assign an IP. The first three lines of the log below show when I connected the phone, and when I switched it to USB tethering. It seems to connect and then disconnect, and reconnect.
I've tried both the USB2 and USB3 ports. As you can see in the logs, I left it connected for 10 minutes.
Jan 21 18:40:58 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 6
Jan 21 18:41:34 kernel: usb 2-2: USB disconnect, address 6
Jan 21 18:41:35 kernel: usb 2-2: new high speed USB device using ehci_hcd and address 7
Jan 21 18:42:36 kernel: br0: port 4(wds0.1) neighbor 7000.60:02:b4:56:8e:40 lost
Jan 21 18:42:36 kernel: br0: topology change detected, propagating
Jan 21 18:42:45 dnsmasq-dhcp[345]: DHCPSOLICIT(br0) 00:01:00:01:1b:1d:29:94:76:df:bf:0e:42:9c
Jan 21 18:43:18 dnsmasq-dhcp[345]: DHCPDISCOVER(br0) 60:02:b4:56:8e:40
Jan 21 18:43:18 dnsmasq-dhcp[345]: DHCPOFFER(br0) 10.0.168.191 60:02:b4:56:8e:40
Jan 21 18:43:24 dnsmasq-dhcp[345]: DHCPDISCOVER(br0) 60:02:b4:56:8e:40
Jan 21 18:43:24 dnsmasq-dhcp[345]: DHCPOFFER(br0) 10.0.168.191 60:02:b4:56:8e:40
Jan 21 18:43:30 dnsmasq-dhcp[345]: DHCPREQUEST(br0) 10.0.168.191 60:02:b4:56:8e:40
Jan 21 18:43:30 dnsmasq-dhcp[345]: DHCPACK(br0) 10.0.168.191 60:02:b4:56:8e:40 DIRECTV-HR44-3069A4EA
Jan 21 18:44:42 dnsmasq-dhcp[345]: DHCPSOLICIT(br0) 00:01:00:01:1b:1d:29:94:76:df:bf:0e:42:9c
Jan 21 18:46:42 dnsmasq-dhcp[345]: DHCPSOLICIT(br0) 00:01:00:01:1b:1d:29:94:76:df:bf:0e:42:9c
Jan 21 18:48:32 dnsmasq-dhcp[345]: DHCPSOLICIT(br0) 00:01:00:01:1b:1d:29:94:76:df:bf:0e:42:9c
Jan 21 18:50:07 syslog: WLCEVENTD wlceventd_proc_event(420): wl0.1: Auth 4C:11:BF:F5:76:8F, status: 0, reason: d11 RC reserved (0)
...  This repeated about 7-8 times ...
Jan 21 18:50:08 syslog: WLCEVENTD wlceventd_proc_event(420): wl0.1: Auth 4C:11:BF:F5:76:8F, status: 0, reason: d11 RC reserved (0)
Jan 21 18:50:12 kernel: usb 2-2: USB disconnect, address 7
Jan 21 18:50:21 syslog: WLCEVENTD wlceventd_proc_event(386): wl0.1: Deauth_ind 4C:11:BF:F5:76:8F, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Jan 21 18:50:32 dnsmasq-dhcp[345]: DHCPSOLICIT(br0) 00:01:00:01:1b:1d:29:94:76:df:bf:0e:42:9c
When I connect the same phone and cable to a Windows PC, I get this from an ipconfig check
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Remote NDIS Compatible Device #2
Physical Address. . . . . . . . . : 02-54-5D-0B-5A-51
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2600:1004:b0a8:1f9a:30a6:ce47:5d61:e063(Preferred)
Temporary IPv6 Address. . . . . . : 2600:1004:b0a8:1f9a:f0ac:4233:19ac:516e(Preferred)
Link-local IPv6 Address . . . . . : fe80::30a6:ce47:5d61:e063%25(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.42.141(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, January 21, 2020 6:38:21 PM
Lease Expires . . . . . . . . . . : Tuesday, January 21, 2020 7:38:21 PM
Default Gateway . . . . . . . . . : fe80::8c96:3bff:fe04:6b01%25
192.168.42.129
DHCP Server . . . . . . . . . . . : 192.168.42.129
DHCPv6 IAID . . . . . . . . . . . : 1141003357
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-E2-CA-94-2C-33-7A-F2-66-27
DNS Servers . . . . . . . . . . . : 192.168.42.129
2600:1004:b0a8:1f9a::24
NetBIOS over Tcpip. . . . . . . . : Enabled
Routers have a limited set of compatible phones to use as a WAN connection. Is the Note 8 in that list?
