Using OpenVPN client and Server at the same time
page_fault
I seem to be having a problem using the OpenVPN server and client at the same time. The server works great but right up until I turn on the client, the server stops accepting connections. I suspect it's listening on the VPN IP rather than the WAN IP but I'm not sure. I have a script to redirect only certain IPs to the VPN client and everything else to WAN but it doesn't work. Attached is my script. Any help would be appreciated.
#!/bin/sh
sleep 2
touch /tmp/000wanstarted
for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
      echo 0 > $i
done
#US VPN
# Delete and table 100 and flush any existing rules if they exist.
ip route flush table 100
ip route del default table 100
ip rule del fwmark 1 table 100
ip route flush cache
iptables -t mangle -F PREROUTING
# Copy all non-default and non-VPN related routes from the main table into table 100.
# Then configure table 100 to route all traffic out the WAN gateway and assign it mark "1"
# NOTE: Here I assume the OpenVPN tunnel is named "tun11".
ip route show table main | grep -Ev ^default | grep -Ev tun11 \
  | while read ROUTE ; do
      ip route add table 100 $ROUTE
done
ip route add default table 100 via $(nvram get wan0_gateway)
ip rule add fwmark 1 table 100
# Define the routing policies for the traffic. The rules will be applied in the order that they
# are listed. In the end, packets with MARK set to "0" will pass through the VPN. If MARK is set
# to "1" it will bypass the VPN.
#  All LAN traffic will bypass the VPN (Useful to put this rule first, so all traffic bypasses the VPN and you can # configure exceptions afterwards)
   iptables -t mangle -A PREROUTING -i br0 -j MARK --set-mark 1
# All traffic from Roku Wireless will use the VPN
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.15 -j MARK --set-mark 0
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.1.25 -j MARK --set-mark 0
Try this VPN_Select.sh script, and U will need to add the directives
route-nopull
script-security 2
route-up /jffs/scripts/VPN_Select.sh
to the Custom VPN dialog box
#!/bin/sh
logger -s -t "($(basename $0))" $$ OpenVPN Client`echo -n $dev | tail -c -1` Selective routing starting.... " $0${*:+ $*}"
MY_VPNTAB=101 # Now read from /jffs/configs/VPNSelect
TAG_MARK=1 # Now read from /jffs/configs/VPNSelect
# Use the OpenVPN environment variables
if [ "X$dev" = "X" ]; then
logger -s -t "($(basename $0))" $$ "*** ERROR not called by VPN Client route-up?...ABORTing!"
exit 1
fi
# Create new table to route VPN traffic when used by RPDB or tagged with MARK. (Credit to  SmallNetBuilder members RMerlin and DJR747)
# or to be associated with a WiFi Guest SSID.
ip route flush table $MY_VPNTAB
ip rule del fwmark $TAG_MARK
ip rule del table $MY_VPNTAB
# Disable Reverse Path Filtering on current VPN network interface:
echo 0 > /proc/sys/net/ipv4/conf/$dev/rp_filter
ip route add default via $ifconfig_local dev $dev table $MY_VPNTAB
#ip rule add fwmark $TAG_MARK table $MY_VPNTAB
#iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range xxx.xxx.xxx.xxx -j MARK --set-mark $TAG_MARK
# Use Routing Policy Database Base (RPDB) as of Apr 2015 to eliminate '-t mangle PREROUTING ' chain corruption
ip rule add from 192.168.1.15 lookup $MY_VPNTAB
ip rule add from 192.168.1.25 lookup $MY_VPNTAB
logger -s -t "($(basename $0))" $$ OpenVPN Client`echo -n $dev | tail -c -1` Selective routing completed.
I have another problem I wonder if you could fix. While this script works it seems now when the OpenVPN client is connected I can only access the gateway (192.168.1.1) but none of the other computers on my network. If I disconnect the OpenVPN client I can access all the computers on my network. Do I need to do some more route magic somewhere? I have enabled Push LAN to Clients in the server portion.
