Hi folks,
what im trying to achieve is as follows: Im running Domoticz on Syno Nas,
however the nas is not placed in an optimal place for the usb 433mhz tranceiver. My router is placed a lot better, so I want attach this usb tranceiver at the router, and running socat to let in communicate with the Synology. I can use the cli and a bit linux, but now im lost.
As seen ttyUSB0 is known as usb gsm driver. I want to make it recognised as FTDI Usb Serial Device. Therefore im think I must compile / install kernel modules i guess. Thats were i struggle: cant find compiled modules or how to compile for my AC66U.
What I also cant find on google is socat on AC66U.
So Is above possible at my router or is it waste of time?
ASUSWRT-Merlin RT-AC66U_3.0.0.4 Sat Dec 27 18:21:40 UTC 2014
admin@RT-AC66u:/tmp/home/root# dmesg | grep usb
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbcore: registered new interface driver usb-storage
usb usb1: configuration #1 chosen from 1 choice
usb usb2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usb 1-1: new high speed USB device using ehci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_ncm
usb 1-1.1: new full speed USB device using ehci_hcd and address 3
usb 1-1.1: configuration #1 chosen from 1 choice
usb 1-1.2: new high speed USB device using ehci_hcd and address 4
usb 1-1.2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver qmi_wwan
usbcore: registered new interface driver cdc_mbim
usbcore: registered new interface driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
usbcore: registered new interface driver option
drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.2
