x3mRouting Using VPN Client Bypass Routing does not work
worf
Hi. guys
I tried to use VPN Client Bypass Routing to configure Amazon AWS with Region CN to wan, but it did not work. Can you help me?
step
1. Accept DNS Configuration: Relaxed;
2. Force Internet traffic through tunnel: Policy Rules(strict)
3. run command x3mRouting 1 0 AMAZON_CN aws_region=CN
Through the above method, it does not work for me. I mean, I want matching ipset list to wan from CN area . Other regions still via VPN
Hi. guys
step
Use this command to check that the ipset list is populated:
ipset -L AMAZON_CN
Verify the iptables routing rule got created. The packets number will increase as traffic traverses the chain.
iptables -nvL PREROUTING -t mangle --line
Display the RPDB routing priority database rules for the fwmarks, VPN Server, VPN Server and LAN Clients:
ip rule
You should see a fwmark for WAN which is Priroity 9990 and it should be listed before the rules for lan clients. Example:
0:      from all lookup local
9990:   from all fwmark 0x8000/0x8000 lookup main
9991:   from all fwmark 0x3000/0x3000 lookup ovpnc5
9992:   from all fwmark 0x7000/0x7000 lookup ovpnc4
9993:   from all fwmark 0x4000/0x4000 lookup ovpnc3
9994:   from all fwmark 0x2000/0x2000 lookup ovpnc2
9995:   from all fwmark 0x1000/0x1000 lookup ovpnc1
10104:  from 192.168.1.150 lookup ovpnc1
10105:  from 192.168.1.151 lookup ovpnc1
10106:  from 192.168.1.153 lookup ovpnc1
10107:  from 192.168.1.154 lookup ovpnc1
10301:  from 192.168.1.165 lookup ovpnc2
10302:  from 192.168.1.149 lookup ovpnc2
10303:  from 192.168.1.152 lookup ovpnc2
32766:  from all lookup main
32767:  from all lookup default
Lastly, try the GLOBAL region to route ALL Amazon traffic to the WAN.
x3mRouting  1  0 AMAZON aws_region=GLOBAL
I am really confused, my method via dnsmasq still does not work.
I just added a command
x3mRouting 1 0 dns_domains dnsmasq_file=/jffs/scripts/dns_domains
wolf@RT-AC86U-E308:/tmp/home/root# cat /jffs/scripts/dns_domains
qq.com
baidu.com
wolf@RT-AC86U-E308:/tmp/home/root# iptables -nvL PREROUTING -t mangle --line
Chain PREROUTING (policy ACCEPT 4096 packets, 446K bytes)
num   pkts bytes target     prot opt in     out     source               destination
1       24  1080 MARK       all  --  br0    *       0.0.0.0/0            0.0.0.0/0            match-set dns_domains dst MARK or 0x8000
wolf@RT-AC86U-E308:/tmp/home/root# ip rule
