I was using the same configuration on my previous router, RT-AC87U, and all was working.
But since I got this RT-AC3200, from the first FW, as soon I configured everything it keep booting and I cannot do anything with it... Need to reset and use restoration software to reconfigure everything.
What can I do to find the problem? Is it related to the RT_AC3200?
Basically the configuration I do is:
VPN
General:
admin
user1 pwd1
user2 pwd2
Advanced settings:
TAP
UDP
1194
Auto firewall
TLS
Username/password Authentication YES
Username/password Auth. Only NO
Allocate from DHCP NO
192.168.100.10 - 192.168.100.19
Direct clients to redirect internet traffic NO
Respond to DNS YES
Advertise DNS to client YES
encryption cipher EAS-256-CBC
Compression Enabled
Manage Client-Specific Options NO
after that I Apply and that is it... need to reset everything again!
Thanks for any advice!
VPN
General:
admin
user1 pwd1
user2 pwd2
Advanced settings:
TAP
UDP
1194
Auto firewall
TLS
Respond to DNS YES
Compression Enabled
