yorgi
Hi
I have an issue and was wondering if there is a fix or its the way it is.
I have a 87u and PIA VPN with merlin firmware.
when I use selective routing to a sepcific IP the DNS and IP shows PIA
when I switch selective routing to Local ISP the DNS of PIA leaks to my Local ISP
If I put prefered DNS like Noroton on Connect to DNS Server automatically area in WAN DNS SETTINGS
and turn off VPN connections I get the right DNS which in my case is Norton DNS and My Local ISP IP is right.
As soon as I enable the VPN client the DNS from PIA automatically takes over for my Local ISP
so basically this is the way it works.
In Redirect Internet traffic to Policy Rules in the VPN client section. I have reserved
192.168.1.90 for VPN which works fine. As soon as I log on to that IP i am on VPN my DNS shows PIA and my IP shows PIA
all my other traffic goes to local ISP so when I switch to DHCP or another Static IP address that is not part of the Policy My IP address shows as my local ISP which that is good but with PIA's DNS and not the routers DNS which I set in the WAN Connect to DNS Server automatically which should use DNS from norton and not PIA. Even if I didn't use preferred DNS isn't the router suppose to give me my Local ISP DNS?
I would think that it should because I am not using the VPN its running in the backround but only for a specific IP address. why is the PIA dns leaking over?
Is this a bug or is there a work around?
The only way I can work around it is to manually enter the proper DNS values when I am on my local ISP
and when I go on the VPN i manually enter the dns to point to the router, this is done on the network adapter of the device.
thankfully I made scripts on the pc that I use the VPN and its not as painfull.
I am thinking that with the original firmware from ASUS you can either have VPN on or OFF so the DNS would resolve properly
but with the Merlin firmware he has it that you can use up to 5 vpn clients and they can all be on at the same time and with selective routing one can go to whichever vpn they want or use local ISP
which works great and there is firewall protection that if the tunnel goes down the vpn traffic is automatically stopped. these are great features
But its scary that the DNS of the VPN leaks over to the ISP
is it really something to be concerned about?
any help or other alternatives would be greatly appreciated.
thanks
thanks
