VPN servers destinations in a scheduled config
San
I have a little situation where my ISP start throttling and messing with the DL bandwidth even with VPN UP so I need to change destinations every 2 to 4 days.
so wondering if any of you has an idea how to setup a schedule where I can define 3 to 5 different destinations using the same client config and switch between them every 3 o 4 days.
any help really appreciated I have been using Merlinf software for wuite some time I do have AC87, AC3100 adn AC3200
Swap ISP,s
You can include several 'connection profiles' in the VPN Client GUI (if you set 'Log verbosity=4' in the GUI you can see them displayed in Syslog)
e.g. specify a list of remote VPN server/port entries, that will be randomly chosen:
remote-random
remote xxx.xxx.xxx.xxx nnn
etc.
and simply schedule cron to issue
service restart_vpnclientX
where 'X' is the appropriate VPN Client.
Alternatively you could try VPN Failover Monitor
remote-random
etc.
I like this idea, but my main concern is about speed,... I guess I'll just have to take the time and try each .ovpn file I have until I find the servers that are the fastest (perhaps closest) to me.
I really wish NordVPN would provide a list of servers by State here in the US...
All I have to go on are the .ovpn files they provide that begin with "us" ...
Thank you so much!
That is why (if you are using RMerlin's firmware) I suggested the VPN Failover Monitor script, so that it would try to ensure the current connected VPN server meets your minimum throughput/performance criteria, and would automatically switch to the next server in the defined VPN_Failover list if the speed is unacceptable.
Swap ISP,s
Totally agree, I can get why some ISP want to shape/limit usage for abuse, but purposefully throttling VPN is just being to cheap. With the extra expense on VPN, surely you have some option for a better ISP?
So I'm assuming the script installed,...but,... what am I missing here? ie. "not found" ??
As there is no alias for 'VPN_Failover.sh' if you are in directory '/jffs/scripts/' then use
./VPN_Failover.sh
otherwise use the full pathname
/jffs/scripts/VPN_Failover.sh
Is there a quick command to stop the script in its tracks?
And thank you so much for your help!!
If you are not using the recommended 'openvpn-event' scripts, then for a graceful termination
rm /tmp/vpnclientX-VPNFailover"
where "X" is the VPN ID e.g. 1, 2 etc.
or
in an emergency (i.e. leaves behind orphaned ' /tmp/vpnclientX-VPNFailover' file)
kill -9 $(pidof VPN_Failover.sh)
What can be done with said orphan?? Can you rm it after you've had to kill it??
You can run the 'status' command
./VPN_Failover.sh   status
then issue the 'reset' command
./VPN_Failover.sh   reset   X
where 'X' is the VPN ID i.e. 1,2 etc.
I'm talking about the '' /tmp/vpnclientX-VPNFailover' file'... if I have to terminate the script and then this orphan is made, what do I need to do with the orphan??
