Hi there,
Like the title says, I am trying to establish Site-to-Site VPN Tunnel between my 2x Asus RT-N66U routers using OpenVPN. One is at my house and the other at my parents.
I tried the PPTP route at first but then read multiple forums' threads advising to go the OpenVPN route for better security/performance.
I have followed a few guides (older firmware) to have this scenario setup. My efforts produced what appears to be an ALMOST successful setup... but not quite yet.
My setup:
Both routers run firmware: 3.0.0.4.374_5517
(H)ome router: 172.16.0.0/24 subnet
(P)arents router: 172.16.1.0/24 subnet
(H)ome router's VPN settings:
Could anyone please shed a bit of light on this poor soul
Many thanks
PS - Afterthoughts
- I am able to successfully connect the two sites (see below)
- I am able to RDP into remote site machines which have port 3389 open in built-in firewall
- I am able to connect to services (media browser, etc.) on remote site machines which have ports explicitly punched in the built-in firewall
- I am NOT able to ping, access machines to see shares, see in My Network Places in either site.
My setup:
- Operates as VPN server
- Windows 7 clients (no antivirus software)
- Operates as VPN client (imported ovpn config file from (H)ome router)
Many thanks
PS - Afterthoughts
- Do both routers need to be setup as VPN servers and connected to each other via VPN clients?
- Should I be using TAP instead of TUN for Interface Type?
- Adding static routes on each router to point to the other? as per this. - no luck unless i am doing something wrong.
