Dismiss Notice
Welcome To SNBForums
VSFTPD - Custom Config
Discussion in 'Asuswrt-Merlin' started by davewolfs, Jan 29, 2013.
  1. davewolfs
    davewolfs Occasional Visitor
    Jan 4, 2013
    49
    How can I setup a custom config so that this file is read when this server starts?
    What command do I need to run to start/stop VSFTPD?
  2. DSwit
    DSwit Occasional Visitor
    Jul 23, 2013
    31
    Canada
    I can't believe your question went unanswered for this long.
    The ftp service can be Enabled under the USB Application/FTP Share tab.
    1. Disable the ftp sharing service.
    2. Ensure the jffs is enabled, formatted and mounted
    3. Create a /jffs/configs folder
    4. Copy /etc/vsftpd.conf to the /jffs/configs folder
    5. Edit the /jffs/configs/vsftpd.conf file to reflect the settings changes you want vsftpd to use.
    6. Enable the ftp sharing service.
    Every time the router or ftp service starts/restarts, the /jffs/configs/vsftpd.conf file will have the final word on what settings are used for vsftpd.
    Cheers
  3. ryzhov_al
    ryzhov_al Very Senior Member
    Jul 23, 2012
    578
    Russia
    You may add some section to existing vsftpd config or replace it by custom one. Details is here.
    service stop_ftpd
    service start_ftpd
Share This Page
