colbond
Having a hard time wrapping my head around this one so hopefully I can explain it properly. This problem has only come up since switching to the ASUS a few weeks ago, so I'm sure it's a configuration issue. Web browsing inside my network works fine (LAN -> LAN). Leaving the network works fine (LAN -> WAN). And incoming works fine (WAN -> LAN). But if I'm inside the network and try to navigate to my public IP or DNS name the connection fails. For example if I'm on my phone at home on cellular and browse to my DNS name the page loads fine, but if I turn on wifi and join the network then it times out. I've looked at the iptables rules and can't spot any obvious problems (OUTPUT is ACCEPT with no rules, INPUT is allowing 80 and 443). None of the outbound filtering features should be enabled. Any ideas?
Thanks!
Thanks!
