[SOLVED]What asus router for 200Mbps fiberspeed
PeterTheGreat
Hello,
I have a subscription at AirVPN.
All my devices have openvpn installed, and are individully behind a VPN.
My plan is to buy an Asus router, compatible with the asus-merlin firmware.
What router is suitable for the 200Mbps up/down?
Thanks,
Peter, Netherlands.
If you want to run the VPN clients on your router and get near line speeds you need a router that has a processor that supports AES-NI. The AC86 and the AX88 meet that requirement.
If you don't plan to run VPN clients on the router there are other options.
Thanks.
