Dismiss Notice
Welcome To SNBForums
What to expect from the N66U?
Discussion in 'ASUS N Routers & Adapters' started by texas05, Nov 8, 2012.
  1. texas05
    texas05 New Around Here
    Nov 8, 2012
    4
    I just purchased a N66U to replace a 2007 Airport Extreme (not sure if it's gen. 3 or 4). I tried a WNDR4500 and it did not outperform the Airport at extended ranges so I returned and got the N66U.
    The N66U had significant slowdown and eventually would drop the connection. I played with the settings; power, channel, etc... upgraded the firmware to .246 and then it bricked and I could not recover it. Amazon is sending a new one.
    What should I be expecting? I'm expecting that a 5+ year newer router will yield better throughput at greater ranges. I not expecting miracles just that it outperform an old Airport Extreme.
    Feedback would be greatly appreciated, thanks!
  2. jerry6
    jerry6 Senior Member
    Jan 24, 2010
    477
    Montreal
    A lot depends on the clients as well . I went from a netgear 2700 v1 to the Asus and transfer speed , range and signal strength all improved .
    FW 246 was no good on my system , had lots of connection drops , 220 and the new 260 work well , if the newrouter comes with 246 I would change it .
  3. vvPULSEvv
    vvPULSEvv New Around Here
    Nov 7, 2012
    3
    Load the new 260 firmware on the replacement. Check that GRO is disabled (LAN, Switch conrol tab). I believe it is by default, but check it to be sure.
    I've been through quite a few N routers(all with the same client adapters) and never seen the speed and range that this thing is giving me.
  4. nubyOz
    nubyOz Regular Contributor
    Oct 28, 2011
    79
    Suggest to load the latest RMerlin build. Is usually more polished. and little bugs fixed.
    Hope he gets a 260 based build out soon. <<< HINT
    I know still waiting for the source :)
  5. smlunatick
    smlunatick Occasional Visitor
    Apr 23, 2012
    20
    I've been moving up thru the various 802.11n levels. I've had:
    D-Link DIR-615 -- slow and "diconnected: often
    Netgear WNDR3700 v1 -- good, reliable, stable -- but died
    Looked for the next level of routers:
    Belkin N600 Dual band -- p.o.s -- no port forwarding rules worked -- returned for credit
    I read on the N66U. It was getting good reviews. Once I found it on sale, it came home. Several issues with firmware (now on 260)
    It's just very powerful and mvery configurable.
  6. texas05
    Nov 8, 2012
    4
    So far the N66U does not have the range of the Airport Extreme. Should I turn up the power? Any suggestions? I just can't believe this is running rings around a 5 year old Airport Extreme.
  7. KevTech
    KevTech Senior Member
    Feb 27, 2012
    444
    United States
    What firmware are you using?
    I had issues with 246 and feel right now the best may be either 220 or 260.
    Still testing 260 so not sure yet if better or worse than 220.
  8. texas05
    Nov 8, 2012
    4
    using .220
  9. jerry6
    Jan 24, 2010
    477
    Montreal
    Strange the n66 has much better range and transfer speed than my old 3700 v1 , linksys 600 and Dlink 855 . Are you using apple products as clients ? maybe that's why your not getting the same results I am , your products were optimized for an apple environment .
    My arheros and intel clients get along well with the 66
  10. texas05
    Nov 8, 2012
    4
    Clients are HTC One X and Samsung Tab
    I'm thinking I need to change the channel bandwidth on 2.4 to 20 MHz only, right now it is on auto 20/40 and I have all kind of competing neighbors networks.
  11. jerry6
    Jan 24, 2010
    477
    Montreal
    That is probably it , I have no competing neighbors , all clear here
Share This Page
