Why is my attached drive showing an sda partition?
curlyimac
I have attached a 3TB seagate to my ac68u router. I used to have it working before with both the pc and macs in the house could read and write to it. but can't remember what it was formatted.
Now I formatted in OS journaled and I see an sda partition. That never used to be there before.
what is the SDA and is it an issue?
sda is the name given to the first disk when it doesn't have a volume label. The second disk would be sdb, etc.
If you give your disk a volume label it will appear as that name instead.
P.S. I assume by "OS journaled" you're referring to MacOS' HFS+. I'd suggest that you use another format that isn't dependent on a proprietary driver, like ext4.
I am going to try NTFS. I didn't think the mac could write to it but I read it can over a network. Thinking maybe that's what I used before.
