MuppetSoul
Hardware: RT-N66U
Firmware: Merlin 378.52_2
Issue: Cannot sync NTP
Error:
I keep getting this error while trying to sync NTP on Slackware. I've tried forwarding and triggering port 123/UDP but it hasn't resolved the issue.
Under Connections, the state of the connections (UDP/Port 123) appears as UNREPLIED.
The only way NTP syncs is through command line by using an alternative port:
This doesn't solve the issue I'm having as I'm left with an IPMI that can't sync with external NTP servers either and I can't use command line on IPMI to force a sync with an alternative port.
Any help would be appreciated.
EDIT: The router has NTP enabled and it syncs just fine.
Error:
27 May 12:31:59 ntpdate[3108]: the NTP socket is in use, exiting
udp 192.168.1.122:123 24.102.6.62:123 UNREPLIED
udp 192.168.1.122:123 173.243.192.18:123 UNREPLIED
udp 192.168.1.122:123 69.28.67.150:123 UNREPLIED
udp 192.168.1.122:123 67.215.197.149:123 UNREPLIED
ntpdate -u pool.ntp.org
