Just yesterday I started having Wifi connection issues on my RT-AC56U router.
Sometimes no devices are able to connect to the router, on either 2.4Ghz or 5Ghz, and after a few reboots, only some devices manage to connect to the router, and every time, different devices, 3 at most I think, over both frequencys
I've tried reverting to 58 FW from 59, I've tries factory reset, I've also tried reverting to original Asus FW, and I get the same behavior with all of the above...
Everything else seems fine, ethernet, and all services that I've configured are working.
Windows machine says can't connect to network, android just fails, and goes back to 'saved'.
I'm guessing there is a HW issues, but thought I'd check here first
