tsunami2311
I just notice that for some reason limiting my wifi to 15 mbit, put cpu usage at 70-90%, which i dont really remeber it ever use that much cpu for just that.
Does say limiting router wifi to legacy mode which 54mbit and using that the limiter for wifi use less cpu usage cause there is actual no bandwidth limiting being done in first place?
Only time I seen that kind CPU usage is when I turned on traditional QOS which turned off CTF, which limited my speed to about 100-110 threw put which when cpu would be peg at 100%.
Not even when my ISP works right and provides me with the 200mbit I should have does cpu usage go that high when CTF is on it barely hit 65% at usage at 200mbit
Should bandwidth limiting really use that much cpu % ?
