Hello,
I have a RT-AC68U with the latest firmware (3.0.0.4.384_21045).
Everything was fine for many months but recently I have problem with the WIFI connections: no client is able to connect to the default (i.e. non-guest) WIFI connections.
They are able to connect to the guest WIFI networks provided that "intranet access" is not enabled.
If I enable intranet access then connecting is unsuccessful (Android devices display "authentication" error even if the WIFI password is 100% correct).
(Besides, the whole router seems a little bit unstable, some minutes ago a wired connection was dropped on a Windows 10 laptop - but this may be a coincidence.)
I tried factory reset and turned off all fancy features (like QoS, etc.) but nothing helped.
Do you have any idea?
Thanks.
Thanks.
