Wireless router with USB3 ports
Discussion in 'Wireless Buying Advice' started by huotg01, Feb 25, 2013.
  1. huotg01
    huotg01 Senior Member
    Feb 3, 2013
    424
    Montreal
    Based on your experience or readings, what is "the best" available high end router with USB3 ports on it ?
    Thanks,
    GH
  2. Log in / Register to remove this ad
  3. Nerre
    Nerre Senior Member
    Oct 17, 2012
    313
    There was another topic the other day about USB 3.0 on a router and the concensus was that there is no use with 3.0 on most routers.
    The router hardware won't be able to utilize the speed, usually routers won't even max out USB 2.0 devices. Also USB 3.0 seems to interfere with 2,4 GHz WiFi.
  4. remixedcat
    remixedcat Senior Member
    May 10, 2012
    403
    Amped Wireless Has announced that they will have USB3.0 802.11ac adapters (at CES). USB3 will be able to take full advantage of the 802.11ac speeds.
    They may have that on thier routers for USB sharing but I'm not quite sure. I would expect that though.
  5. huotg01
    Feb 3, 2013
    424
    Montreal
    I don't see why routers would not max out USB2 devices ?
  6. Nerre
    Nerre Senior Member
    Oct 17, 2012
    313
    USB 2.0 is 480 Mbit/s as far as I know, how many routers even have that throughput WAN-LAN? If they could handle it on USB, how come they don't handle it on WAN/LAN transfers?
  7. stevech
    stevech Part of the Furniture
    Mar 13, 2010
    6,661
    San Diego
    not a wirespeed issue. The use of the file system overhead for a USB drive, especially NTFS rather than a Linux file system, limits the transfer speeds. Takes much more CPU power than in a typical router to cope.
  8. huotg01
    Feb 3, 2013
    424
    Montreal
    One thing I know is that I have a better throughput when using my NAS (a WD MyBookLive) than when using my USB drive connected to the RT-N66U.
  9. stevech
    Mar 13, 2010
    6,661
    San Diego
    WiFi routers with attached USB disks are for very light duty.
  10. Limoges_box_builder
    Limoges_box_builder New Around Here
    May 28, 2013
    1
    So if a wifi router is only good for small use of an external hard drive, then how do you suggest I make my USB 3.0 external hard drive visible tot he rest of my home network (without leaving it plugged into my desk top PC).?
  11. greyclock
    greyclock New Around Here
    May 25, 2013
    9
    Another thought on USB 3.0 is that it interferes with one of the bands... cant remember if it is the 2.4ghz or 5ghz one but reviews concerning the N65u (ASUS's refresh of the famed n56u) point to a issue with USB 3.0 cables causing interference. Using a shielded cables helps, but doesn’t seem to completely solve the issues.
    I will post a little blurp on this when I get mine in the mail...... there should be other information available on this issue via the forums. Not certain if this just affects ASUS 65u routers or if all usb 3.0 enabled routers have issues
  12. Fraoch
    Fraoch Senior Member
    Jan 16, 2013
    211
    Use a NAS. Many have USB 3.0 ports and you can connect USB 3.0 hard drives to them. They will share files much faster than a router.
    Of course you can also plug a USB 3.0 drive into a USB 2.0 socket. On a router it may not make much of a difference in speed since it's so CPU-constrained. On a NAS or a PC it will slow it down, but it will still work fine.
  13. Fraoch
    Jan 16, 2013
    211
    It's USB 3.0 and 2.4 GHz and yes, it's all USB 3.0 devices unless proper shielding is built in. Most manufacturers haven't properly addressed it yet.
    Intel has a whitepaper on it:
    http://www.usb.org/developers/whitepapers/327216.pdf
Share This Page
