VanishingHope
Moved into a house nearly 2 years ago. I plan on wiring my home with Cat6 (solid, 4-pair, 550 mhz tested, plenum, unshielded) and rewiring the coax with RG6 (I believe it's RG6). Still in the design/planning phase. I've read many of the SNB articles regarding this.
I'm still budgetting and determining costs of local installation companies to compare cost of having them do it versus doing it myself. I have some experience taping/mudding drywall and have terminated many cables & setup many small home networks for family... just none of them required through-wall cable management.
My biggest quesetion for the forum is: should I put in conduit for future drops? Based on my home layout, I have a feeling some larger sections of each room will need to be cut out. While the walls are "open", should I spend the extra money to have conduit put in? If so, what diameter is sufficient?
Is there a limit to how many runs I put together? My family room, I plan on 5 drops -- 3 Cat6 and 2 Coax. It's the only room receiving so many. Is it ok to run all 5 of these within the same conduit/section?
Any other hints or tips for are more than welcome. I'm planning to have this complete by end of October.
Thank you,
--Aaron
Thank you,
--Aaron
