Andreas Werner
I want to use WOL (Wake-on-Lan) over VPN, but I didn't manage it yet. It's no option either to use WOW (Wake-over-WAN) using a port forwarding, or using a SSH script.
I have tried:
* Port forwarding from WAN: Failed due to the fact, that a specific port can only forwarded to one maschine, not more. I have to do an implementation accessing two devices.
* Using an IP range for VPN within the same network as used for LAN, but outside the DHCP range. Failed due to the fact that there is an error displayed all times that networks "overlaps".
* I found no option to define broadcast routes between two subnets (Lan & VPN).
* I found no option to set up DHCP options for VPN, like range or fixed IPs.
Still implemented:
* VPN is working fine, secured by passphrase and certificate, I can access the running devices within LAN from VPN
Hardware used:
ASUS RT-N66U with Merlin latest build.
Any suggestions??
I have tried:
Still implemented:
Hardware used:
Any suggestions??
