1900 AC, switch, 2 access points, looking for ease of setup and use
CD2
I’ve been reading SNB for about a year and enjoying the reviews.
It’s time to replace the D-link N router. Our wifi bandwidth needs are not huge and our devices are at most dual-band AC, so 1900 dual-band AC seems about right. I don't need printer or NAS capacities.
For coverage I’ll also need a switch and a couple of AC dual-band access points, all to be connected by ethernet. So four devices in total.
Here’s my question. There’s roughly equivalent gear from several major brands and I can afford what it costs. What I most want is a set of devices likely to be robust, unfiddly, easy to set up, and unlikely to require hours on the phone with tech support.
This may be mainly a brand-reputation question. In any case, if the criterion is not bleeding-edge performance but least-likely-to-give-trouble, where would you steer me?
You haven't given enough information. ;)
What coverage area in SqFt is needed? How many floors/levels? What type of building materials does the building use? Which D-Link router model do you have now? Where is it located relative to the coverage area? Can you provide a diagram showing location layout, device location(s)?
Have you considered moving the main router to a central location? (I would not recommend 'jumping' into multi AP setups until you have exhausted other options first).
http://www.snbforums.com/threads/sh...-go-with-the-rt-ac1900p-v3.34748/#post-281391
The link shows how a single router handles a very large multi level home and at a less than optimal location too.
Limiting yourself to AC1900 class + AP's is not only increasing the complexity of your network (possibly needlessly), but more than likely you are limiting the performance possible too (even with your current clients).
i will give you a suggestion based on what you have posted and thats ubiquiti
start with a ubiauiti edge router and a switch with POE and for the access points some of the ubiquiti unifi ap's in AC , the ac lite ones sound about right for what you need
the edge router doesnt have wifi onboard so you might need a third AP depending on coverage
ubiquiti stuff works and works well is pretty easy to setup
pete
Thanks for your thoughtful reply. I appreciate your implied point that I should see what coverage a new router provides before getting too many access points.
But part of what I need to service is a separate building some distance from the house, and I expect at least one more need for coverage some distance away.
In any case, this really was not intended to be an open-ended question about how to cover a particular area, which is why I am not burdening you all with house details. So if it's OK, I'd prefer to take it as given, for purposes of this thread, that I really will need a wireless router plus two dual-band access points, and stick with my original question about who is likely to sell me an easy-to-manage set of boxes to do that.
Just wanted to report on results. I got an Edgerouter Lite plus an Edgeswitch 8 and two AC lite APs and I've been very happy with the results. Being able to put the APs where I want them has been key for coverage. Once up and running it has been solid. For (my very basic SOHO) setup I just used the GUIs and wizards and a few youtubes -- the Crosstalk Solutions videos are especially helpful. Forum archives held clues when things got weird. Thanks to those who engaged my OP.
