DavidHK
I live in a 4 story building with 12 apartments (in Vietnam if it makes any difference).
The main internet comes into the front reception and then is ported out to each apartment. Each apartment has its own WiFi unit (basic TP-Link units).
I replaced the existing router (old TP-Link) with my Asus RT-AX56U.
When setting it up and connecting directly to my laptop, I can log-into the router via 192.168.1.1. Once connected back to the internet it works fine.
But if I then try to log-in to my router with 192.168.1.1 when connected to the internet, I go to the front reception router log-in page. See attached image...
1) Can/should I change my router settings to avoid this?
2) Is this s symptom of poor technical network installation on their part?
* Note their RJ45 LAN cable has only 4 wires, not 8... but I still get 50+MB on it. However there is occasionally a lot of lag... which has me thinking...
Thanks for any assistance on understanding this and what I could do...
