2.4 Guest SSID enabled, but normal 2.4 disabled, webui or ssh ?
gen87u
Hello,
Actually both normal 2.4 and 2.4 guest SSID are enabled, but the normal 2.4 isnt used at all.
Can I disable the normal 2.4 SSID and keeping the 2.4 guest SSID in the webui, or only with SSH ?
Thanks.
No you can't disable the normal SSID and keep the guest because the guest interfaces are dependant upon the normal interface.
The way you keep the normal ssid 'disabled' is by not using it. Give it a name like 'CIA-ONLY' and don't share the password with anyone. :)
As long as no traffic is flowing through it, it is as if it was disabled. ;)
