2.4GHz, mode question (54,347,800Mbps)
bodean
Is there any reason NOT to use 800 Mbps mode on a netgear R7800 router? The options are 54, 347, or 800 Mbps.
Yes 800 in 40MHz if you want speed but shorter range and 246.7 in 20MHz for longer range lower speed as you said
