2.5g WAN usage for 1g internet-AX86U
homeofwind
Hi, can someone let me know any point for using DUAL WAN mode for 1g internet? what is the benefit of it? ISP modem has 2.5g port. I wonder if speed is limited to 1g, is there any point doing that?
OzarkEdge
Part of the Furniture
ronorbar
if I connect a switch to the router(with 2 port 2.5g), is it better to connect it to a 2.5g port or a 1g port?
OzarkEdge
A 2.5GbE uplink is obviously faster/better than a 1GbE uplink.
OE
homeofwind
You have to decide what this single 2.5GbE port is more useful for in your case - WAN or LAN. You have both options in GUI. Dual WAN is unrelated.
I assume the AX86U's 2.5g port is a WAN port too but there is no signal when I plug the cable to that port. Does it mean I can only use the 1g Internet WAN port?
Tech9
You have to enable 2.5GbE port as WAN in the GUI. The default configuration is LAN.
Tech9
Please, check the User Manual at least once before you continue asking this type of questions. Thank you!
