2nd Guest Wifi setup queston
Gordy
I am using RT-N66U router running Tomato 1.28 shibby fw.
I already have one guest wifi running good separate from my private wifi.
I was wondering if there are any known issues to run second guest wifi?
If not I do need little guidance, here is my Vlan setup, currently I have Vlan3 as my guest wifi, so if I need to add a 2nd guest wifi do I just select Vlan4 and for bridge I choose the same Lan1 (br1), as I have shown below but have not added yet?
And for the Virtual Wireless I would just choose wlo.2 and for bridge same Lan1 (br1) is that all I need to do?
Please advise.
One other question I have is if we have devices listed in the Device List that no longer exist, how can we remove them from the list? Thanks
The more SSID's you run on a single channel, the worse the performance is - each SSID takes up a certain amount of time on the channel that will not be available to transfer data...
This is also why one should only enable Guest Networks if absolutely needed...
That is good to know, based on that I will refrain from setting up additional ssid.
Thank you kindly, much appreciated.
G Where is my Guest Network UI tab? Facebook??? ASUS N Routers & Adapters 4
