3.0.0.4.385_10000 UNSTABLE on RT-AC68U
Boorock70
As the topic says it all, 3.0.0.4.385_10000 is the Unstable king of all times !
- Constant random "internet connection" drop outs (with or without Download Master activated)
You simply lose the internet access on RT-AC68U (both wired and WiFi) but Download Master keeps on running (downloading)
It's NOT an ISP or bandwidth issue... I'm an experienced RT-AC68U and a heavy Download Master user for 6 years, I know how to use the device/app !
- Internet Status randomly shows "disconnected" and after a while (1 to 3 mins.) connection gets repaired.
But... as you can guess, it goes "disconnected" again.
- While those absurd issues are happening, the Download Master options under the USB Applications tab goes mad "Check Update" option goes missing !
Tried to factory reset, reboot and even format the attached USB Drive but... NO !
- Nothing helps.
I'm using the router mode in a very simple setting with no VPN, AiMesh etc.
Just 5 clients accessing internet while Download Master running 24/7 !
Why are these "things happening" ASUS ?
Why can't you do things right for god sake ?
Ronald Schwerer
LOL. 28 posts (currently) and every one of them is bitching about DM. Having never used or installed it, I think I'll keep it that way.
