3.0.0.4_374.34_2 reports as 3.0.0.4.270.24
WRobertE
I downloaded RT-N66U_3.0.0.4_374.34_2.zip and unzipped to RT-N66U_3.0.0.4_374.34_2.trx. After loading I reset to factory defaults. My RTN66U now reports its running 3.0.0.4.270.24?
What am I doing wrong?
Either you flashed the wrong one, your web browser cache is lying, or the flash didn't properly complete. Try flashing without having any USB disk plugged in (and reboot the router after unplugging all disks).
If it still fails, try a different browser, or try using Asus's Firmware Recovery tool.
Fixed - Thanks
Thanks for the reply and for the great work on this firmware.
I had tried it twice before posting.
I ended up downloading the software again, then used the WPS button to restore to defaults, then uploaded to the router using a different browser and ... bingo ... it reports correctly.
Really weird... but working now. Thanks again.
