[ 3004_388.11 alpha Build(s) ] available build(s)
octopus
Part of the Furniture
No support on Alpha builds.
3004.388.11 (xx-xxx-2025)
- NOTE: AiCloud has been removed from Asuswrt-Merlin due
to its security track record. Use a VPN if you
need remote access to your data.
- NOTE: For developers, the Tomato legacy files (tm*.*)
are no longer included with the webui. Please
update your addon pages accordingly.
- NEW: Redesigned Traffic Monitor pages.
- Uses Chart.js for Realtime and Last24 pages
- Removes legacy Tomato code
- Last 24 can be zoomed in and panned (mouse wheel
and pinch-to-zoom gestures are both supported)
- Realtime and Last 24 now show as bits/s instead
of bytes/s
- Settings moved from the tab to the dropdown menu
- Removed NVRAM database location option and added
JFFS. Also removed rarely used start-of-month
setting.
- UPDATED: OpenVPN to 2.6.16.
- UPDATED: libcap-ng to 0.8.4 (to be in sync with upstream)
- CHANGED: TrafficMonitor stats can now be saved to JFFS,
and removed support for saving to NVRAM.
- REMOVED: outdated setuprsa.sh script.
- REMOVED: AiCloud support, due to security reasons.
