3006.102.5 Guest Network Pro issues in Aimesh nodes after reboot
Southmad1977
Im running 3006.102.5 in my RT-AX88U Pro along with 4 Aimesh node. My nodes are a combination of 3 RT-AC66U B1 (3004.386.14_2) and 1 RT-AX58U V2 (3004.388.9_2gnuton2) that had no issues with my prior version of Merlin (3006.102.4).
Since the last update (actually the following day, which then became relevant) I noticed that none of my clients were able to connect to either of my guest networs (IoT and Guest) as invalid IP configuration showed up.
As i have seen this in the past I deleted all the networks and set it again in specific nodes. All seemed to work just fine for that day, problem was again noticeable the following day, since I have a daily reboot of all my nodes @4.30AM and my router @4.31, all my system reboots in sequence.
Once the sequence happened I noticed that only the router seems to connect with the clients in the guest network (I dont have any issues in the main), but the nodes which continues to reject connection with an Invalid IP configuration (I see this in my phone). To fix this I made a dummy refresh in the Guest Network Pro (removed a node, added again) and everything was up again.
My though at this point is that the Guest Pro configuration its not been refreshed after reboot and probably some old configuration remained in the NVRAM of the nodes (Probably some VLAN changed when I reset the original configuration on the first step). This also happened after I reboot any node,
Any ideas (rather than not rebooting daily :) will be appreciated!)
Same issue here. I did not notice it until a day after updating to 102.5. First thing I tried was rebooting the node (RT-AX3000) as that was not done when updating the main router (RT-AX86U Pro). After that did not work, I removed the node and waited awhile to add it back. Still nothing. All of my IoT devices are connected to the main router while the node is in the bedroom with lamps in the same room and other devices nearby. I can force a bind on the node but that is not a solution. The node is running 388.9_2 and did not have an issue before.
EDIT: Adding the node back also needed the box enabled in the GN Pro tab -> IoT Network -> AiMesh settings.
Yeah.. annoying. At this point I was only able to do it with a dummy refresh. Perhaps someone knowledgeable can do a script with a cron job to refresh after each reboot cycle until get solved.
It has been recommended time and again to run Asus firmware on the nodes. It is also noted that mismatch of firmware versions between router and AiMesh nodes can cause issues. Although the AC66U B1 is or was a super router (I have one on the shelf in reserve), using those as AiMesh nodes will reduce the capabilities of newer routers (limit bandwidth and channels of the 5 GHz). Best to use the older devices as Access Pionts.
And yes, a daily reboot is not necessary in most instances.
I don't disagree but the AX58 which is newer behaves in the same manner. Before doing that will move to the prior version of Merlin. That doesn't seemed to be an issue.
Also, rebooting or not, if I lose power Router and access point will reboot and will lost connection in all the IoT devices so definitely not a viable solution.
I am having a similar problem. I have a BE-88U as my main router with another BE-88U as a node and a AC-88U as another. With the previous Merlin build, I was able to connect the BE-88U's via MLO by simply enabling it via the GUI.
But when I updated to the latest build this week, the BE-88U node went stupid. It showed up as a node, but no clients would connect. I tried a factory reset on both BE-88U's and tried again same result: turning on MLO would make the BE-88U node go stupid; turning off MLO would not help only a factory reset of the node would work. The old warhorse AC-88U had no issues.
Currently the network is stable but with MLO turned off, but I am curious if there was a change to the firmware that could have caused this.
Would recommend to downgrade for the moment. That is what made my whole network stable again.
When the node was removed, the box next to RT-AX3000 was blank and had to be checked. I don't know why dirty updating to 102.5 made the node not detect devices. Perhaps I could have just deleted the enitre IoT Network and set it back up but what I did kicked it going again. Hope that helps.
Got it. So basically your fix it's to remove the node from the systems and then add it to the existing guest Network.
Yes. I think what happened for me was by removing the node and adding it back, it was recognized in the IoT Network but had "lost" it's checkmark. If the IoT network had been deleted instead of the node and creating the network again, the node box would have been marked by default. Does that make sense? This was my first time setting up GN when 3006.x was released for the RT-AX86U Pro. Let me know if you had luck.
Count me in as one of the 'lucky' ones with this issue as well.
BE92 as main router, AX56 as mesh node. Working fine with 102.4 on the BE92 but not with 102.5.
102.5 fixes a different issue for me so it's like choosing between the plague and cholera at this point :)
I've gone back to 102.4 for now, but hope there's a solution to this in the next FW maybe? Won't be anytime soon I suppose :(
In my scenario, on 102.5, I don't even get the option to enable the AiMesh setting for the guest network on the AX56 btw. It just says that "the wifi connection has reached the maximum" so rebooting or recreating the node does nothing for me. My clients never join. The BE92 doesn't have GNP though only "Smart Home Master" so that may be why this is different?
Smart Home Master is apparently a different feature than Guest Network Pro.
FAQ: Everything you need to know about multiple SSIDs, Smart Home Master, and Guest Network Pro
It appears, per several other discussions, there may be some feature limitations when trying to combine different router models (using AiMesh master/node) in which one supports Guest Network Pro while the other supports Smart Home Master. Several other discussions referencing Asus's Smart Home Master:
It appears, per several other discussions, there may be some limitations or incompatibility when trying to combine different router models (using AiMesh master/node) that only support one or the other feature. Several other discussions referencing Asus's Smart Home Master:
Thx but I'm aware that it's different or I wouldn't have said it myself as well as the fact that it completely overlooks the fact that things are running fine on 102.4 (at least from a guest network perspective)
Today I was able to do it and had no impact. Removed all the guest networks, then removed the nodes,.added the nodes again and added the guest. Same thing. Revering again to 102.4
I did a clean by the book install and config on 102.5 without any luck, reverted back to 102.4 and set everything up successfully. I then converted my AX56 mesh node from Merlin to stock Asus FW, and upgraded my main BE92 router to 102.5 FW and the changes stuck.
So I'm now able to use my BE92 on 102.5 with guest network propagated successfully with all clients reconnecting without issue.
Bottom line: despite reading in various places that all FW should be Merlinin a mesh network, it's better to keep your Mesh nodes on stock Asus FW
DId you did a factory reset on the nodes after going to stock? Also..I assume it's the latest stock per model correct?
Did you had to do a clean install after moving from 102.4 to 102.5? Thanks!
