octopus
Part of the Furniture
OneDrive
www.asuswrt-merlin.net
No support on Alpha builds
GT-BE98_PRO
RT-BE96U
New Builds: 2024-09-25
GT-BE98_PRO
RT-BE96U
3006.102.xx (xx-xxx-xxxx) 2024-09-25
- NEW: Added mDNS support to the router's local name resolution
(nss).
- UPDATED: OpenVPN to 2.6.12.
- CHANGED: Support importing Wireguard config files that
contain multiple AllowedIPs, Address or DNS
declarations.
- CHANGED: Re-added firmware version display on Sysinfo page
(as you can't copy the version string from the
header banner, this one can be).
- CHANGED: VPN killswitch will now only be active if the
VPN client itself is enabled. If you stop/start
the client yourself over SSH, you need to also
update the enabled/disabled nvram setting.
- FIXED: Generated web certificate wasn't using the FQDN
for Namecheap DDNS users.
- FIXED: DNSDirector and Tor pages would fail to properly load
in some environment.
- FIXED: CVE-2024-2511, CVE-2024-4741, CVE-2024-5535 &
Implicit rejection for RSA PKCS#1 in openssl
(backport from Ubuntu by RSDNTWK)
- FIXED: UPnP options were missing on WAN page for models
with multiservice WAN support.
- FIXED: Guest Network table would still be shown on the
DNSDIrector page if DNSDirector isn't enabled.
- FIXED: VPN Fusion-related popup showing when editing
an existing DHCP reservation - removed.
- FIXED: 320 MHz chanspec would show as 160 on the Wifi
icon status.
- FIXED: Wifi icon status not properly showon on quad-band
Wifi 7 models.
(nss).
declarations.
